update I did find how to create the block that allows me to add tags in one set up steps but I am guessing there is something wrong in my kepware config.
Have you made sure the Haas end is setup properly? See guide here How to Collect data using HAAS Serial (Machine Data Collection) – MachineMetrics
They do look the same as my setup.
Which model Moxa device are you using. I am still unable to get the device to connect to Kepware
I'm using the NPort 5110A.
Have you checked your cabling? I'm setup with this cable 6 ft DB25 to DB9 Serial Modem Cable M/F - DB9 Cables & DB25 Cables | Cables | StarTech.com Canada
and a null modem adapter DB9 Serial Null Modem Adapter - DB9 Cables & DB25 Cables | Cables | StarTech.com Canada
