Two question about the Gauge component.
- The rightmost number of the scale is getting clipped. If I adjust the width the topmost number gets clipped. How do I prevent the clipping?
- I am using the same ranges on the inner and out axis. Is there a way to disable the numbers showing up on the inner axis since the values are duplicated and it looks messy to have the extra numbers crowded in?
`Welcome to the forum.
Please right-click on the component in the Project Browser, Copy, and paste the component's JSON here. Then format it as shown in Wiki - how to post code on this forum. That way we can reproduce the problem and find a fix.
"type": "ia.chart.gauge",
"version": 0,
"props": {
"value": 50,
"secondaryValue": 100,
"outerAxis": {
"maxValue": 120,
"width": 1,
"ranges": [
"start": 0,
"end": 80,
"width": 8,
"color": "#77B6D8"
"color": "#6E94D7",
"end": 105,
"start": 80,
"width": 12
"color": "#7A6BD5",
"end": 120,
"start": 105,
"width": 16
"data": "value",
"percentRadius": 100,
"show": true
"innerAxis": {
"maxValue": 120,
"width": 0,
"data": "secondaryValue",
"percentRadius": 85,
"show": true
"animate": true,
"backgroundColor": ""
"meta": {
"name": "Gauge"
"position": {
"x": 15,
"height": 137,
"width": 224
"custom": {}
It looks like the clipping of the text is determined by the clip mask in the SVG component. I can't see a way to change it. Regular HTML clipping could be overwritten by adding style.overflow : visible but that doesn't work in this case.
A "fix" is to reduce the font size. style.fontSize : 8px works but you may find it a bit small or that it doesn't match your other components.
I was able to fiddle with sizing and get 12pt font to not clip, so in lieu of a 'true' solution that will help.
Thanks.
