I was wondering if there was a way for the contents in an embedded view to scale based on the screen size.
This embedded view is using coordinate container view.
It would be like how percent mode works in coordinate container. Except, instead of every component scaling, the view itself scales like it was an image.
I want to eliminate having to scroll if the screen is smaller than the view size. I would like it to scale like its an image based on the screen size.
im not sure what the goal is.
but you can use vh and vw
or a comboination of % and vh vw with calc
to apply such width/height values you need to be in fixed mode (as percentage mode changes everything to a number)
Doesnt look like its just the labels, the pumps are way to small too.
@Mitchell_Lagenour
You have more options to scale though, if you set it to percent and fill in the aspect ratio, maybe you have a bit better results
Also @jlandwerlen, as i stated in the solution in the topic you linked, its really not a solution and more a work around xd
I wouldnt advice to put the text inside the svg, its way to bothersome, instead you should put a lineheight, or overflow on the labels. (and mayb a hover effect to show the full text on hover?)
