Having trouble logging into my Ignition Project
I am having trouble logging into my Ignition Project. I can login to all other aspects of ignition but when I launch the project form the designer, my login fails. I am following along with the IU lessons and am unable to find where to set up logins for this project.
In gateway web interface, you need to create any non-default user sources and/or Identity Providers you wish to use.
Then in your project properties, you select the appropriate one for your project. If Perspective, it must be an identity provider. For Vision, set a user source for classic authentication, or set an identity provider.
