Hi, I’m in need of help urgently. Tonight I upgraded from 7.9.1 to 7.9.2 on Ubuntu 16.04 (headless). Also upgraded to latest Java 1.8-131 from 1.8-121. Following the upgrades my Gateway fails to start. Wrapper log shows a permissions error at some point following attempt to execute main. I’ve tried rolling back the Ignition version, with no luck. Haven’t tried Java yet, working on that next…
Sent in an email to support, but hoping someone here might have something to try. Clearly permissions are broken somewhere, but there is no indication of what/where.
Thanks.
Clint.
Here is the section showing the error:
INFO | jvm 1 | 2017/04/30 21:22:33 | I [o.e.j.s.ServerConnector ] [01:22:33]: Started ServerConnector@33801e47{SSL,[ssl, http/1.1]}{0.0.0.0:8060}
INFO | jvm 1 | 2017/04/30 21:22:33 | WrapperSimpleApp:
INFO | jvm 1 | 2017/04/30 21:22:33 | WrapperSimpleApp Error: Encountered an error running main:
INFO | jvm 1 | 2017/04/30 21:22:33 | WrapperSimpleApp Error: MultiException[java.net.SocketException: Permission denied, java.net.SocketException: Permission denied]
INFO | jvm 1 | 2017/04/30 21:22:33 | WrapperSimpleApp Error: at org.eclipse.jetty.server.Server.doStart(Server.java:347)
INFO | jvm 1 | 2017/04/30 21:22:33 | WrapperSimpleApp Error: at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
INFO | jvm 1 | 2017/04/30 21:22:33 | WrapperSimpleApp Error: at com.inductiveautomation.catapult.Jetpad.start(Jetpad.java:323)
INFO | jvm 1 | 2017/04/30 21:22:33 | WrapperSimpleApp Error: at com.inductiveautomation.catapult.Catapult.start(Catapult.java:135)
INFO | jvm 1 | 2017/04/30 21:22:33 | WrapperSimpleApp Error: at com.inductiveautomation.catapult.Catapult.main(Catapult.java:62)
INFO | jvm 1 | 2017/04/30 21:22:33 | WrapperSimpleApp Error: at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
INFO | jvm 1 | 2017/04/30 21:22:33 | WrapperSimpleApp Error: at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
INFO | jvm 1 | 2017/04/30 21:22:33 | WrapperSimpleApp Error: at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
INFO | jvm 1 | 2017/04/30 21:22:33 | WrapperSimpleApp Error: at java.lang.reflect.Method.invoke(Method.java:498)
INFO | jvm 1 | 2017/04/30 21:22:33 | WrapperSimpleApp Error: at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:325)
INFO | jvm 1 | 2017/04/30 21:22:33 | WrapperSimpleApp Error: at java.lang.Thread.run(Thread.java:748)
INFO | jvm 1 | 2017/04/30 21:22:33 | WrapperSimpleApp Error: Suppressed: java.net.SocketException: Permission denied
INFO | jvm 1 | 2017/04/30 21:22:33 | WrapperSimpleApp Error: at sun.nio.ch.Net.bind0(Native Method)
INFO | jvm 1 | 2017/04/30 21:22:33 | WrapperSimpleApp Error: at sun.nio.ch.Net.bind(Net.java:433)
INFO | jvm 1 | 2017/04/30 21:22:33 | WrapperSimpleApp Error: at sun.nio.ch.Net.bind(Net.java:425)
INFO | jvm 1 | 2017/04/30 21:22:33 | WrapperSimpleApp Error: at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:223)
INFO | jvm 1 | 2017/04/30 21:22:33 | WrapperSimpleApp Error: at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:74)
INFO | jvm 1 | 2017/04/30 21:22:33 | WrapperSimpleApp Error: at org.eclipse.jetty.server.ServerConnector.open(ServerConnector.java:326)
INFO | jvm 1 | 2017/04/30 21:22:33 | WrapperSimpleApp Error: at org.eclipse.jetty.server.AbstractNetworkConnector.doStart(AbstractNetworkConnector.java:80)
INFO | jvm 1 | 2017/04/30 21:22:33 | WrapperSimpleApp Error: at org.eclipse.jetty.server.ServerConnector.doStart(ServerConnector.java:244)
INFO | jvm 1 | 2017/04/30 21:22:33 | WrapperSimpleApp Error: at org.eclipse.jetty.server.Server.doStart(Server.java:384)
INFO | jvm 1 | 2017/04/30 21:22:33 | WrapperSimpleApp Error: … 10 more
INFO | jvm 1 | 2017/04/30 21:22:33 | WrapperSimpleApp Error: Caused by: java.net.SocketException: Permission denied
