I have thousands of these exceptions in my logs and I would like to remedy them. But, I am not sure how to track this guy down. Any pointers?
INFO | jvm 2 | 2020/12/01 11:43:16 | E [S.SystemUtilities ] [17:43:16]: Error running function from system.util.invokeAsynchronous
INFO | jvm 2 | 2020/12/01 11:43:16 | com.inductiveautomation.ignition.common.script.JythonExecException: TypeError: 'NoneType' object is not callable
INFO | jvm 2 | 2020/12/01 11:43:16 | at org.python.core.Py.TypeError(Py.java:265)
INFO | jvm 2 | 2020/12/01 11:43:16 | at org.python.core.PyObject.__call__(PyObject.java:409)
INFO | jvm 2 | 2020/12/01 11:43:16 | at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:822)
INFO | jvm 2 | 2020/12/01 11:43:16 | at com.inductiveautomation.ignition.gateway.script.GatewaySystemUtilities.lambda$_invokeAsyncImpl$0(GatewaySystemUtilities.java:139)
INFO | jvm 2 | 2020/12/01 11:43:16 | at java.base/java.lang.Thread.run(Unknown Source)
INFO | jvm 2 | 2020/12/01 11:43:16 | Caused by: org.python.core.PyException: TypeError: 'NoneType' object is not callable
INFO | jvm 2 | 2020/12/01 11:43:16 | ... 5 common frames omitted
INFO | jvm 2 | 2020/12/01 11:43:16 | com.inductiveautomation.ignition.common.script.JythonExecException: TypeError: 'int' object is not callable
INFO | jvm 2 | 2020/12/01 11:43:16 | Caused by: org.python.core.PyException: TypeError: 'int' object is not callable
INFO | jvm 2 | 2020/12/01 11:43:17 | E [S.SystemUtilities ] [17:43:16]: Error running function from system.util.invokeAsynchronous
