Help getting started - HMI building in
Background: I have minor experience with using Allen Bradley Studio 5000 over 5 years ago in my previous job. I have never created an HMI from scratch, only modified existing programs. Haven’t been online with a PLC since mid 2020.
I am currently trying to use the Ignition Maker Edition (non-commercial use only) to build a proof of concept that could then be scaled up with proper approvals.
Project details:
  • Workplace consists of miles of conveyance
  • Work order system is clunky and unintuitive
  • The building SCADA system is resource intensive on laptops and completely unusable on any tablet/mobile device
  • Primary goal
    • Provide technicians with visual indicators of where work is physically located and priority of said work for increased efficiency
    • Visual indicators will link to the work order website for technicians to perform required documentation steps
    • Tapping on visual indicator brings up the work order number, details, and link to the work order page.
  • Secondary goal (if possible)
    • Also connect to building PLCs to display equipment condition states
    • Track equipment faults and generate fault indicators once certain thresholds are breached.
Barriers:
  • I don’t even know where to get started. I have a project started in designer, have a view started, but don’t see any type of draw or shape function like I think I remember from AB. For the equipment display I only need to be able to create rectangles and curves.
  • Data acquisition/upload - I doubt I’ll be able to get permission to query the WO system directly at first. I need to be able to upload an excel sheet at first to provide the HMI with data for indicators
  • SCADA - Same boat, I doubt I’ll be able to get permission to have my app “talk” to the building PLCs at first.
You describe commercial use. (Even at home, you are describing commercial use, IMO.) Do not even start something with Maker if you wish it to become commercial later.
Use Ignition Standard and develop with that. (Some commercially useful parts are omitted from Maker, too.) Test with two-hour-at-a-time trial mode.
Ignition is not like AB HMIs.
Go through all of Inductive University. That will knock out the bulk of your questions.
Start by creating:
(1) A docked header view
(2) A docked footer view
(3) A docked menu side view
(4) A main flex container view with a table
(5) A main coordinate container view with a dozen randomly placed icons.
(6) Figure out how to navigate between the two main views with the sidebar menu, updating random information on both the header and footer
(7) Figure out how to populate the table with your excel spreadsheet (using the search in this forum)
(8) Figure out how to get table clicks to navigate to the appropriate icon and display the important information from the table click in the footer.
Come back here with specific questions on these eight steps, one at a time. When you complete these eight steps your objectives should become more clear.
….and welcome to the community.
