Help me ! I want to overlay object. Please advise me how
Object is image and label. The label blinking on image for Identify abnormal locations on image.
Thank you
Best regards
P.NATTAPON
Perspective or Vision?
Perspective: are you using a coordinate container? if you are, I'm not sure what the issue is, as you can simply drag components to where you want. If you're not using a coord container, then you should be to (easily) allow overlapping objects. You can overlap components inside other components but it's far less intuitive and more advanced (using negative margins, position, etc.).
