hello my name is carlos ruiz de mexico
for use:
system.serial.configureSerialPort (port, bitRate, DataBits, handshake, hardwareFlowControl, parity, stop bits)
a library call number is required or how.
this is my scripting but it appears the error
system.serial.configureSerialPort (\ port = “COM3”, \
system.serial.BIT_RATE_9600 bitRate = \
system.serial.DATA_BITS_8 DataBits = \
system.serial.HANDSHAKE_NONE handshake = \
hardwareFlowControl = False, \
system.serial.PARITY_NONE parity = \
StopBits = system.serial.STOP_BITS_1)
system.serial.write (“COM3”, “hello”)
I mark the error that is:
File “event:actionPerformed”, line 1, in
AttributeError: ‘com.inductiveautomation.ignition.common.script.Scr’ object has no attribute ‘serial’
how can I send a serial hello by pressing a button.
