Hello:
I am using Linux OS and Ignition 8.1. I just uploaded a 3rd party unsigned module. but state is “loaded” but not “Running”
could anybody please help with this?
Thank you very much.
Hello:
If your module is only Loaded and not Running that most likely means you haven’t correctly configured the module’s module.xml to define your GatewayHook or don’t have a GatewayHook at all.
You’ll have to share more details for more help.
Dear Kevin: Thank you so much for your reply, I tried this and that, but could not fix the issue. Since I am a new user, I could not upload any files, but the pom.xml file I used can be found here:
The package names you have declared in code don’t match the actual package structure: https://github.com/ricardocabrita/ignition8-customDevice-example/blob/25f1e0c4a182f9a31ea60a754ac01474bf55a158/opc-ua-device-gateway/src/main/java/com/github/exampledevice/ModuleHook.java#L1
