Hi, I have this database created and I want to insert data but I get error
[i]CREATE TABLE inventory
id int NOT NULL AUTO_INCREMENT,
name varchar(255) NOT NULL,
description varchar(255) not null,
PRIMARY KEY (id)
)[/i]
I have a button to insert data into the db, this is the script
[color=#4000BF]name= event.source.parent.getComponent(‘name’).text
description = event.source.parent.getComponent(‘description’).text
system.db.runPrepUpdate(“INSERT INTO inventory (name,description) VALUES (?,?)”,[name],[description])[/color]
I get the following error
[color=#FF0000]Traceback (most recent call last):
File “event:actionPerformed”, line 5, in
java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepUpdate(INSERT INTO inventory (name,description) VALUES (?,?), [Product1], [u’Description1’], , false, false)
caused by Exception: Error executing system.db.runPrepUpdate(INSERT INTO inventory (name,description) VALUES (?,?), [Product1], [u'Description1'], , false, false)
caused by GatewayException: Connection Error: Datasource "[u'Description1']" does not exist in this Gateway.
caused by SQLException: Datasource "[u'Description1']" does not exist in this Gateway.
Ignition v7.6.4 (b2013112117)
Java: Oracle Corporation 1.7.0_25[/color]
