Help system.util.sendRequest to run .exe in Gateway
I am trying to have a project script run a .exe on the gateway and then return the results to the client project script. If running the .exe in a similar manner on the client, it works just fine. Here I need the .exe to run on the gateway. The .exe is on the gateway C drive with GatewayLocalDir pointing to it.
Here is the Gateway Message Handler:
def handleMessage(payload):
    import subprocess
    try:
        path = payload["path"]
        process = subprocess.Popen([path], stdout=subprocess.PIPE)
        output, _ = process.communicate(timeout=10)
        return output
    except Exception as e:
        return str(e)
Here is a snippet of the project’s script:
try:
    import base64
    from java.io import ByteArrayInputStream
    from javax.imageio import ImageIO
    payload = {"path": GatewayLocalDir}
    result = system.util.sendRequest("Gateway", "runLabelGenHandler", payload)
    image_bytes = base64.b64decode(result)
    input_stream = ByteArrayInputStream(image_bytes)
    return ImageIO.read(input_stream)
In the end, it’s not returning an image and failing the try. Please help
The most likely cause is that the Ignition gateway service is not running as a user with access to that location, or cannot run the executable for some other permissions related reason.
You can have the Ignition service run as a particular user, or you can grant the LOCAL_SYSTEM virtual user explicit access to the folder/executable you're trying to invoke.
When granting Everyone Read/Write access to the .exe, it still seems to not be returning an image as it should. Do you know if LOCAL SYSTEM explicitly needs to be added? Thank you
