[Help] Tag Event Scripting error
I am trying to insert data into a database based on a tag event script changing value, i am just trying to make it run a named query but the tag event script gives me an error saying project name is required in the gateway which i have already done.
Here is the error
Error executing script.
  File "<tagevent:valueChanged>", line 2, in valueChanged
	at com.inductiveautomation.ignition.gateway.script.GatewayDBUtilities.interpretWithOptionalProject(GatewayDBUtilities.java:463)
	at com.inductiveautomation.ignition.gateway.script.GatewayDBUtilities.runNamedQuery(GatewayDBUtilities.java:378)
java.lang.IllegalArgumentException: java.lang.IllegalArgumentException: Project name required for script execution: the Gateway Scripting Project is not set.
Hmm, it’s complaining that the “Gateway Scripting Project” is not set. You can find it under Config > System > Gateway Settings in the Ignition Gateway.
https://docs.inductiveautomation.com/display/DOC81/Gateway+Settings
Ah, this is actually a little more confusing.
Can you share your code? I don’t think you’re specifying the project correctly.
This code or the query?
	Fired whenever the current value changes in value or quality.
	Arguments:
		tag: The source tag object. A read-only wrapper for obtaining tag
		     properties.
		tagPath: The full path to the tag (String)
		previousValue: The previous value. This is a "qualified value", so it
		               has value, quality, and timestamp properties.
		currentValue: The current value. This is a "qualified value", so it has
		initialChange: A boolean flag indicating whether this event is due to
		               the first execution or initial subscription.
		missedEvents: A flag indicating that some events have been skipped due
		              to event overflow.
	system.db.runNamedQuery("UpdateTable")
You need to specify both a project and a path in your runNamedQuery call.
Thank you for the answer, could you please show me what that would look like?
system.db.runNamedQuery("MyProjectName", "path/to/my/NamedQuery")
Also, see system.db.runNamedQuery - Ignition User Manual 8.1 - Ignition Documentation and the "Gateway Scope Syntax" example.
Sorry to bother you again but i still cant seem to make this work, ive tried to put in the path for the query but it still tells me its not found
This is the path to the query and ive tried with with and without the \query on the end
system.db.runNamedQuery("Dportv1", "C:\Program Files\Inductive Automation\Ignition\data\projects\Dportv1\ignition\named-query\UpdateTable\query" , {} )
The path/to/my/NamedQuery is the folder and name as seen in the designer tree, not the file on the server’s filesystem. With forward slashes.
Where can i find this path?
If you didn't make folders to organize your named queries, then supply just the query name.
Thank you! this is the solution
