Help with a problem that occured with database update
Hello everyone. Today I ran into an error that I’ve never encountered before, and that I’m not 100% sure how to parse. This is the error:
  File "<event:actionPerformed>", line 30, in <module>
	at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:364)
	at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:262)
	at sun.reflect.GeneratedMethodAccessor197.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepUpdate(UPDATE MasterFabParts2 SET est_cost = ? where Part_Number = ? and ID = ?, [NaN, M GOR001 200 011, 55], , , false, false)
	at org.python.core.Py.JavaError(Py.java:495)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:186)
	at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:427)
	at org.python.core.PyObject.__call__(PyObject.java:404)
	at org.python.core.PyObject.__call__(PyObject.java:408)
	at org.python.pycode._pyx316.f$0(<event:actionPerformed>:8)
	at org.python.pycode._pyx316.call_function(<event:actionPerformed>)
	at org.python.core.PyTableCode.call(PyTableCode.java:165)
	at org.python.core.Py.runCode(Py.java:1275)
	at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:623)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:168)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:265)
	at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:55)
	at com.sun.proxy.$Proxy27.actionPerformed(Unknown Source)
	at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
	at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
	at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
	at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
	at javax.swing.plaf.basic.BasicButtonListener.focusLost(Unknown Source)
	at java.awt.AWTEventMulticaster.focusLost(Unknown Source)
	at java.awt.Component.processFocusEvent(Unknown Source)
	at java.awt.Component.processEvent(Unknown Source)
	at java.awt.Container.processEvent(Unknown Source)
	at java.awt.Component.dispatchEventImpl(Unknown Source)
	at java.awt.Container.dispatchEventImpl(Unknown Source)
	at java.awt.Component.dispatchEvent(Unknown Source)
	at java.awt.KeyboardFocusManager.redispatchEvent(Unknown Source)
	at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(Unknown Source)
	at java.awt.DefaultKeyboardFocusManager.dispatchEvent(Unknown Source)
	at java.awt.KeyboardFocusManager.dispatchAndCatchException(Unknown Source)
	at java.awt.KeyboardFocusManager.processCurrentLightweightRequests(Unknown Source)
	at java.awt.KeyboardFocusManager$4.run(Unknown Source)
	at java.awt.event.InvocationEvent.dispatch(Unknown Source)
	at java.awt.EventQueue.access$500(Unknown Source)
	at java.awt.EventQueue$3.run(Unknown Source)
	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
Caused by: java.lang.Exception: Error executing system.db.runPrepUpdate(UPDATE MasterFabParts2 SET est_cost = ? where Part_Number = ? and ID = ?, [NaN, M GOR001 200 011, 55], , , false, false)
	... 55 more
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: SQL error for "UPDATE MasterFabParts2 SET est_cost = ? where Part_Number = ? and ID = ?": The incoming tabular data stream (TDS) remote procedure call (RPC) protocol stream is incorrect. Parameter 4 (""): The supplied value is not a valid instance of data type float. Check the source data for invalid values. An example of an invalid value is data of numeric type with scale greater than precision.
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:327)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:301)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:258)
	at com.inductiveautomation.ignition.client.script.ClientDBUtilities._runPrepStmt(ClientDBUtilities.java:137)
	at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:260)
	... 53 more
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: The incoming tabular data stream (TDS) remote procedure call (RPC) protocol stream is incorrect. Parameter 4 (""): The supplied value is not a valid instance of data type float. Check the source data for invalid values. An example of an invalid value is data of numeric type with scale greater than precision.
	at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:196)
	at com.microsoft.sqlserver.jdbc.SQLServerStatement.getNextResult(SQLServerStatement.java:1454)
	at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.doExecutePreparedStatement(SQLServerPreparedStatement.java:388)
	at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement$PrepStmtExecCmd.doExecute(SQLServerPreparedStatement.java:338)
	at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:4026)
	at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:1416)
	at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeCommand(SQLServerStatement.java:185)
	at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeStatement(SQLServerStatement.java:160)
	at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.executeUpdate(SQLServerPreparedStatement.java:306)
	at org.apache.commons.dbcp.DelegatingPreparedStatement.executeUpdate(DelegatingPreparedStatement.java:102)
	at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper$SRPreparedStatement.executeUpdate(SRConnectionWrapper.java:871)
	at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.RunPrepStmt.runUpdateQuery(RunPrepStmt.java:65)
	at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.AbstractUpdateQuery.run(AbstractUpdateQuery.java:34)
	at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.AbstractDBAction.invoke(AbstractDBAction.java:76)
	at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:345)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
	at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:816)
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:583)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226)
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1156)
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:511)
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1088)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
	at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:52)
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:119)
	at org.eclipse.jetty.server.Server.handle(Server.java:517)
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:306)
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:242)
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:245)
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95)
	at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:75)
	at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceAndRun(ExecuteProduceConsume.java:213)
	at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:147)
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:654)
	at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:572)
	at java.lang.Thread.run(null)
Ignition v7.8.2 (b2016030813)
Java: Oracle Corporation 1.8.0_281
It seems that the error is coming from attempting to assign something that is not a number back to my estimated costs, but I’m unsure how this could be happening. I’ll share my code because odds are good someone here will be able to catch it more easily than I.
# This button should be pressed very rarely as it is going to result in an exceptionally long query and take a long time.
process_cost_dict = {'ASSEMBLY': 5,...,'MACHINING': 0} # a long dictionary of loaded costs per process
if system.gui.confirm('WARNING: This process is going to take an extended period of time.  Only confirm if you are sure.'):
	query = 'SELECT Part_Number, ID, Process_1, Process_2, Process_3, Process_4, Process_5, Process_6, Process_7, Process_8, Process_1_Hours, Process_2_Hours, Process_3_Hours, Process_4_Hours, Process_5_Hours, Process_6_Hours, Process_7_Hours, Process_8_Hours FROM MasterFabParts2'
	data = system.db.runQuery(query)
	dataset = system.dataset.toDataSet(data)
	for row in range(dataset.rowCount):
		id = dataset.getValueAt(row, 'ID')
		part_no = dataset.getValueAt(row, 'Part_Number')
		est_part_cost = 0
		for i in range (1,9):
			process_i = dataset.getValueAt(row, 'process_' + str(i))
			process_i_hours = dataset.getValueAt(row, 'process_' + str(i) + '_hours')
			print process_i
			process_i_hours
			if (process_i is None) or (process_i_hours is None):
				est_part_cost += 0
			else:
				est_part_cost += process_cost_dict[process_i] * process_i_hours
			print est_part_cost
		print est_part_cost
		est_part_cost_query = 'UPDATE MasterFabParts2 SET est_cost = ? where Part_Number = ? and ID = ?'
		est_part_cost_values = [est_part_cost, part_no, id]
		system.db.runPrepUpdate(est_part_cost_query, est_part_cost_values)
I’ve been wracking my brains over this for the past 30 minutes, but I decided it would probably be more time effective to get other eyes on it. Thank you so much for all of your help.
Either of these help?
https://community.safe.com/s/question/0D54Q000080hINk/the-incoming-tabular-data-stream-tds-remote-procedure-call-rpc-protocol-stream-is-incorrect
It looks like the error your SQL db is throwing back is The incoming tabular data stream (TDS) remote procedure call (RPC) protocol stream is incorrect. Parameter 4 (""): The supplied value is not a valid instance of data type float. Check the source data for invalid values. An example of an invalid value is data of numeric type with scale greater than precision. at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:196) Might be worth making a post on dba.stackexcahnge or a similar database specific forum as this isn’t something Ignition is doing, but rather your db not liking something.
Could be worth looking to see if any of the following are occurring from the solution in this post: numpy - What are all the possible calculations that could cause a NaN in Python? - Stack Overflow
It seems that SQL is not liking NaN being passed to it (unless I am misinterpreting the error).
