Help with Alarm Status Table and alarm acknowledge
This is my error. I am new at ignition and I don't know where to correct this.
When I click the acknowledge button it says that my user does not have access.
My user is in the correct role but I do not know how the role translates into the vision window or the alarm status table component.
I do not know if the problem is in my gateway security settings or in the vision client window or in the Alarm Status table settings.
Please help.
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Error executing function 'Alarming.acknowledge': The current user does not have the required roles for this operation.
Enable the permission in project properties
Add roles with comma separated if needed. More info in the manual Vision Project Properties
Thank you. That was my problem.
You can mark it as “Solved”
What other areas should I look at if this is still not allowing users to acknowledge?
Need to provide more info.
Vision or Perspective? What version? Where are you seeing the error?
