I am wondering if you have some tips for this: We want to create our own alarm status fo when the user click or double click on the alarm event it will take him direct to the windows where the alarm is realted.
Ex: If the alarm is “High Temperature Tank 1”, when he click over the alarm it will go to the window where the Tank 1 is
First, I added a Data Type Parameter to my all my Data Types that have alarms called ‘Page’. Then I added this ‘Page’ parameter to each alarm tag under Documentation. Now I can tell it what page that instrument is on.
Next I created a script called tracealarm. This will swap to the page I provided if it exists.
# This is for ignition version 7.7 or higher....
def tracealarm(path):
import system
import re
tag = str(path).split(':/')[1].split(":")[1] #This is the tag
grf = system.tag.getTagValue(tag + ".Documentation")
if grf != '':
system.nav.swapTo(grf)
else:
print "This alarm has no page on record."
Next on the alarm the alarm status table, I enabled the onDoubleClicked Extension Function to call my script.
