I have used a menu bar component, but a horizontal scrollbar appears. I want to hide the scrollbar, but I tried setting overflow-x: hidden using css style, and it’s not working.
Does anyone know how to resolve this? Please share your suggestions!
Thanks & Regards,
Arifrahuman A
Are you placing the CSS style in the advance stylesheet? Or are you using the style property on the component its self?
I have tried both styles, but they are not working.
Okay, could you provide some screen shots of your styling? With advanced style sheets and on the style property itself?
This is my CSS stylesheet code,
and here is the applied component property style.
Okay so I recreated your scenario and found what the issue was. On the menu tree component there is a div called menu-wrapper wrapper root.
There was a style being applied to this root which was over riding the style you had made.
As you can see the overflow was being set to auto.
And because you where targeting the overflow-x, this overflow was not being overridden. Edit: It's because overflow is not inherited by child HTML components in CSS
In your advanced stylesheet you can target this class like so:
.menu-tree .menu-wrapper {
overflow-y: auto;
overflow-x: hidden;
For future reference, always inspect the element if there is a style that is not being applied. It's certainly tripped me up a couple of times.
Sure @Zachary Thank you!!
