Help with Kepware
Just I have started the same. I have connected Kepware to Ignition.
Now I need
How to create tags in Kepware.
how tags need to fetch in Ignition.
In Ignition I have connected the machines to Allen Bradley PLC. so how tags can be fetch from kepware.
That will be explained in the Kepware documentation. It really isn't a question for the Ignition forum.
Ignition comes with Allen-Bradley OPC drivers so you can read tags directly from the PLC.
Why do you think you need to "fetch from Kepware"?
I'm not sure what your question has to do with the OP? Other than being about the same opc UA server, kepware. I've marked as off topic, as I don't have the super powers to split it off
I would eliminate Kepware. It is an extra point of failure, configuration and maintenance that you don't need.
thank you all, I got the connection. I enabled YES for below options in Project Property
after this I got connection.
Care to share the solution? Someone searching the forum and finding this topic will be in exactly the same state they were in before reading it i.e. still looking for a solution
