Basically I have a table that consists of data Like:
Line timestamp AttrName AttrValue
33601 2015-01-01 10:30:00 Bolt 1 0.05
33601 2015-01-01 10:30:00 Bolt 2 0.06
33601 2015-01-01 10:30:00 Bolt 3 0.05
33601 2015-01-01 10:30:00 Bolt 21 0.07
I got the Pivot down, but it comes out like this:
Line timestamp Bolt 1 Bolt 2 Bolt 3 ..... Bolt 21
33601 2015-01-01 10:30:00 0.05
33601 2015-01-01 10:30:00 0.06
33601 2015-01-01 10:30:00 0.07
What I want is:
Line timestamp Bolt 1 Bolt 2 Bolt 3 ...... Bolt 21
33601 2015-01-01 10:30:00 0.05 0.06 0.05 0.07
33601 2015-01-01 10:31:23 0.04 0.06 0.04 0.05
etc.
Code Below… I think I am missing a Group function somewhere???
SELECT *
FROM
SELECT M.Line,
S.timestamp,
S.SampleUUID,
S.AttrName,
CAST(S.AttrValue AS float(3)) AS fixValue,
CAST(substring(S.AttrName, 15, 3) AS INT) AS ATR_Index
FROM QUAL_SampleData S
INNER JOIN QUAL_Sample M
ON S.SampleUUID = M.SampleUUID
WHERE S.TimeStamp > '{Root Container.Date Range.startDate}'
AND S.TimeStamp < '{Root Container.Date Range.endDate}'
AND S.AttrName LIKE 'Thickness%'
AND MeasNo = '1' AND AttrValue < '1'
) DataTable
PIVOT
AVG(fixValue)
FOR AttrName
IN (
[Thickness Bolt 1],[Thickness Bolt 2],[Thickness Bolt 3],[Thickness Bolt 4],[Thickness Bolt 5],[Thickness Bolt 6],
[Thickness Bolt 7],[Thickness Bolt 8],[Thickness Bolt 9],[Thickness Bolt 10],[Thickness Bolt 11],[Thickness Bolt 12],
[Thickness Bolt 13],[Thickness Bolt 14],[Thickness Bolt 15],[Thickness Bolt 16],[Thickness Bolt 17],[Thickness Bolt 18],
[Thickness Bolt 19],[Thickness Bolt 20],[Thickness Bolt 21]
) PivotTable
ORDER BY timestamp ASC, ATR_Index ASC
