I need some help replacing system.tag.getTagValues with system.tag.readAll. I cant seem to figure out how to pull out just the value and not the quality. any help would be appreciated. here is my existing script using getTagValues
[code]
query = “SELECT displayname, devicename from devices”
tag = event.source.getComponent(‘Dropdown 1’).selectedStringValue
if event.propertyName in [“devices”, “refresh”]:
table = event.source.getComponent(‘Table’)
newData = []
header = [“Displayname”, “Identifier”, “Current Throughput”, “Today’s Throughput”, “devicestate”]
res = system.db.runQuery(query)
tagPaths = []
for row in res:
tagPath = row[1]
tagPaths.append("%s%s"% (tagPath,tag))
tagPaths.append("%s/yestmcftotal"%tagPath)
tagPaths.append("%s/PrimaryInterval"%tagPath)
results = system.tag.getTagValuesl(tagPaths)
idx = 0
for row in res:
displayName = row[0]
tagPath = row[1]
newData.append([displayName, tagPath, results[0+idx], results[1+idx], results[2+idx]])
idx += 3
table.data = system.dataset.toDataSet(header, newData)[/code]
