Help with - Transform string value
I get the value from a lookup table. It has a starting string "Form:"
I wanted to try transform options and that got the output in the form of a dataset. how would I pick second row.
2024-06-26 21_35_05-Edit Binding_ Destination.props.text
To select a particular cell in a dataset you can use the following syntax:
Dataset [Row, Column]
In your case, to get the first column of the second row you would do:
{value}[1,0]
You can also achieve your desired outcome with a single expression:
Thank you so much
