Hi guys, so I encountered this error "Scripting[system_util_tag]", can you help how to find and debug this error
Hi guys, so I encountered this error “Scripting[system_util_tag]”, can you help how to find and debug this error?
because i have no idea where to look at because of lack of info in the error.
Advanced Thanks!
you are somewhere using in your code a function “send”() and give it a property while it doesnt need one.
Yes, i think so too, but I cant find where did i put that script :upside_down_face:
btw thanks for the comment sir!
im guessing its in an expression runScript()
you can use find to search through scripts and expresssions
okay, ill try that, thanks sir.
it worked, i found the existing script, Thanks to you sir.
Nice :slight_smile:
usualy the logs show where it happend, but sometimes you just have to use the good old ctrl+f xd
