is there a way to hide pages in a report? like for example if i have a checkbox and the total pages i have is 5 and the user only wants to see pages 1 to 3, then it would hide pages 4 and 5. anyway this is possible? thank you
I have the same question.
I need to make a page visible or not depending of a parameter.
Is it possible?
I was checking my topics and just coming back to this so it can go up the topics list. Is this possible? Is there a workaround we can do? Not just hide the contents of the page but hide the page itself
No. The only way to complete omit something is to use nested tables and selectively supply zero rows to the ones to omit.
I copy and paste the same report. I created a 2nd report and kept all my templates and any extra pages that might go in and out of the main report.
Otherwise, you have to hide each label.
I don't know if this feature is recent, but report pages can now be hidden by parameter.
- Create a boolean parameter. Set it to
falseortrue.
- Select the page and open the Key Browser and Property Inspector.
- Drag the page hide parameter to the Page Properties | Hidden.
- Test in the Preview tab. With the parameter set to true the page should be hidden.
Alternate method:
- Create the boolean parameter.
- Select the page.
- Property Inspector | Page Properties | Right-click on "Hidden" | Use Dynamic Data Key.
- Select the
data_keyfield which appears, hit the search icon and select the parameter key.
