Hide X Axis Selector in Easy Chart
Hi All,
I am wondering if there is a way to hide the time selector widget at the bottom of the EasyChart component in Ignition Vision. I cannot find any property that allows it, but it would be great if was possible! I am on Ignition 8.1.41. I have attached a picture of the widget below for reference.
Thanks!
Screenshot 2025-09-16 at 1.09.56 PM
Maximize the chart. It’s a tick box about 3/4 the way down in the properties.
They’re not asking to hide the actual X-Axis, but the Realtime Selector.
The maximize option unfortunately hides the Pen Selector tool on the left, is there a way to keep that while only hiding the time selection?
A little introspection, and there isn't much in vision you can't do.
Place the following in your configureChart extension function if you wan't this always hidden.
Or you can add the for loop to a custom method on the chart that could be called from anywhere if you wanted to be able to toggle the visibility from a button.
def showComp(comp,name,show=True):
    for this in comp.getComponents():
        if name in str(this.__class__):
            this.setVisible(show)
            break
        showComp(this,name,show)
#if you choose to make this a custom method, then these calls would go to where
#you are calling the custom method.
#This hides the Label, Duration Spinner, and Unit Selector ComboBox
showComp(self,'RealtimeDateRange',False)
#This hides the pause button
showComp(self,'RTPauseButton',False)
