Hiding root folders in Tag Browse Tree object (Vision)
Is it possible to hide the root folders in a Tag Browse Tree?
I am using the filter to successfully filter out subfolders within my Tag Provider, but the MQTT Transmitter folder still shows.
Have you tried setting to false "Show Root node" and "Show Root Handles"?
Thanks. Yes, I've tried that but all that does is expose the "Root" folder:
I'm trying to minimize what is on the tag tree since feedback from my operations team was to simplify the HMI as much as possible.
I missed the obvious and seems I can set the "Root Node Path" property directly to my tag provider (in the form of [Tag provider]\folder1). For anyone trying to do this you can right-click any tag / folder and select "Copy Path".
I was struggling with the filterTag extension function and this is far easier. Note that the filterTag function doesn't seem to work on Historical Tag Providers.
