Hello, everyone!
I am working on a work project in perspective and am struggling with the idea of how to make a tab container have less tabs when lower access level users are logged in. To be specific - I have session configuration and information tabs, which currently are set up in a way, that when a non-administrator user logs in, the tab just shows a view, that the person does not have access to this information, but it would be much more neat, if the tabs would just not show at all. I have an idea how to check authentication levels and when to check them, I just don't really understand how am I to write down tab quantity changes...
I hope I wrote down my issue clearly, but if I have missed something please let me know! And thank you in advance, any help is greatly appreciated.
I can't test it right now but maybe you can bind the tab property to whatever you use to evaluate access rights, and generate tabs in a transform ?
I have no idea what happens to the content of tabs when doing this, so it might not work. I guess you'll have to try and see.
If you Shift-right-click on the tab view in the Project Browser and use Copy JSON you can see the structure like this:
"custom": {},
"params": {},
"props": {},
"root": {
"children": [
"meta": {
"name": "EmbeddedView"
"position": {
"tabIndex": 2
"type": "ia.display.view"
"meta": {
"name": "EmbeddedView_0"
"position": {
"tabIndex": 1
"meta": {
"name": "EmbeddedView_1"
"meta": {
"name": "root"
"props": {
"currentTabIndex": 2,
"tabs": [
"Zero",
"One",
"Two"
"type": "ia.container.tab"
You may be able to script the root and props sections to do what you want based on the user access level.
