Guys I need Help,
Server Specs:
- HP Proliant G9 4cores CPU, Not Hyper Threading
- Windows Server 2008R2 Standard Vm, 4Cores CPU, 12Gb RAM
Ignition Gateway:
- ver. 7.9.6
- 45564 Tags
- 4 PLC connection
- MySQL DB
- 6 Client Stations
Issues in the Field:
- After a long Run of the Gateway CPU usage would go up to 100% which cause operational problems.
- When we Reboot the Gateway it will go back to normal.
- is there any fixed?
Using our Office Server Dell PowerEdge 24cores CPU & 128GB RAM, Support Hyper Threading:
- We Run the Gateway Server Vm with 8cores CPU & 12GB of RAM. it Works Fine
- But for our simulation Test.
