Good morning, my name is Felipe. I have analyzed the ignition gateway daily and noticed that Ignition is consuming a lot of memory and the CPU trend is almost 100%, as shown in the image below.
Analyzing the virtual machine, these are the settings:
Also analyzing in Ignition config the Initial Java Heap Size (in MB), these are the settings, as shown in the image below:
I would like to know if there is anything I can do to improve the performance of Memoria, because every time it reaches 100% it drops the system and it is necessary to restart the Ignition server, when the system is restarted, the memory resumes with a low value and as the days go by, it increases until it reaches 100% and brings down the system. stays in that loop. I was wondering if one of the options could be to increase the memory heap, for example, from 8192 to 10240. If this negatively affects the performance and performance of Ignition, I would like to know if there is another one to improve performance of my system.
The database is installed on another virtual machine, I am talking about this only for information level.
I appreciate all the help now.
