High use of CPU
Hi.
I’ve been watching the use of CPU in Ignition 7.9.5, for some reason it goes up to 96% and it doesn’t go down after a restart. I checked the threads and say many of them that describes:
Thread [webserver-230] id=230, (RUNNABLE)
java.util.ComparableTimSort.minRunLength(Unknown Source)
java.util.ComparableTimSort.sort(Unknown Source)
java.util.Arrays.sort(Unknown Source)
java.util.ArrayList.sort(Unknown Source)
java.util.Collections.sort(Unknown Source)
com.inductiveautomation.ignition.common.util.TimelineList.sort(TimelineList.java:24)
com.inductiveautomation.ignition.common.util.TimelineList.add(TimelineList.java:117)
com.inductiveautomation.ignition.common.util.TimelineList.add(TimelineList.java:68)
com.inductiveautomation.ignition.common.util.Timeline.addSegment(Timeline.java:46)
com.inductiveautomation.gateway.tags.history.query.SCExecRecord.addToTimeline(SCExecRecord.java:185)
com.inductiveautomation.gateway.tags.history.query.DatasourceQueryExecutor.initialize(DatasourceQueryExecutor.java:651)
com.inductiveautomation.ignition.gateway.sqltags.history.query.AggregateHistoryQueryExecutor.initialize(AggregateHistoryQueryExecutor.java:78)
com.inductiveautomation.ignition.gateway.sqltags.history.query.HistoryWriter.initLoader(HistoryWriter.java:140)
com.inductiveautomation.ignition.gateway.sqltags.history.query.HistoryWriter.execute(HistoryWriter.java:210)
com.inductiveautomation.ignition.gateway.sqltags.SQLTagsManagerImpl.queryHistory(SQLTagsManagerImpl.java:1297)
com.inductiveautomation.ignition.gateway.project.ProjectSettingsCache$ProjectDefaultTagManagerFacade.queryHistory(ProjectSettingsCache.java:666)
com.inductiveautomation.ignition.gateway.servlets.gateway.functions.QueryTagHistory.invoke(QueryTagHistory.java:96)
com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:405)
javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:837)
org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:583)
org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226)
org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1160)
org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:511)
org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1092)
org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:52)
org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134)
org.eclipse.jetty.server.Server.handle(Server.java:518)
org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:308)
org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:244)
org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:273)
org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95)
org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93)
org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceAndRun(ExecuteProduceConsume.java:246)
org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:156)
org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:654)
org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:572)
java.lang.Thread.run(Unknown Source)
What is the meaning of that?.
Is your historian SQL database server getting bogged down? How is the performance looking on that? Do you have proper indexes on the historian tables?
This might provide some helpful steps to narrow it down.
[TUTORIAL] How to Debug High RAM Usage - Ignition - Inductive Automation Forum
