I would like to know how many project can support an Ignition Gateway ?
Is the limit of projects depend on the number of Gateway or our server specifications ?
Thanks,
Thanks,
I don’t think there is any hard capped limit on how many projects you can have. The obstacle you’re likely to run into is that you having a lot of projects–each with its own users–will slow down the gateway. The gateway itself is limited in how much RAM it can use which varies depending on whether you’re using the 32-bit or 64-bit installation. Of course the number of projects you can safely run on the gateway without slowdown will depend very much on the content of the projects (is there a lot of database activity or thousands of tags?) and how good your server hardware is.
