Has anyone done a mass import of data from another historian? I’d like to explore the possibilities of importing an iFix database. Ideally, I would duplicate the tag structure in Ignition, let it start logging data, then backfill the Ignition database with the iFix data.
I know that the historian has an ODBC connector, so I can write queries against it in SQL. I know that I could populate that in Ignition. However, there are intricacies such as the iFix historian compression, Ignition’s compression, and getting all the other database requirements right in Ignition.
Any pointers?
