Historical Data Synchronization Issue
Hello,
We are experiencing an issue with historical data synchronization between an Ignition Standard Gateway and an Ignition Edge Gateway.
1. System architecture
  • Central Gateway: Ignition Standard 8.3.1.
  • Remote Gateway: Ignition Edge 8.3.1.
  • Both Gateways are connected through a Gateway Network (GAN).
  • Historical data is forwarded from the Edge Gateway to the central Gateway.
  • A Splitter is used to distribute historical data to different PostgreSQL destinations.
2. Synchronization issue
Historical data is no longer syncing correctly between the Edge and the central Gateway.
  • The attached graph compares the historical values stored in both Gateways, showing the difference between the data recorded by each one.
  • The Current Sync ID remains at 6713023 (see attached screenshot).
  • In Shared Executions, sync manager / edge historian showed average execution times of approximately 35 minutes.
Has anyone experienced a similar issue with Edge Historian synchronization in Ignition 8.3.1?
Any suggestions on how to fix this issue would be greatly appreciated.
Thanks in advance for your help!
