Hey all!
I have recently purchased the Ignition SQL Bridge module with hopes and dreams of setting it up to log process variables on an existing system… and then “replay” those values back into a controllogix processor to simulate the realtime process in the PLC.
I have a laptop with Ubuntu 12.04, latest & licensed version of Ignition SQL Module, and PostgreSQL talking to my Controllogix over EtherNet/IP.
Here’s where I’m at so far. So far… I’m just logging 1 real value using a Historical Group using timestamps. From there, I’ve created a SQL query tag that polls the database at a specified interval and writes a value back to the PLC.
SQL TAG Query:
SELECT HIST_PV
FROM TEST
WHERE t_stamp >= NOW()- ‘{[~]ReplayDateDiff}’::INTERVAL
ORDER BY t_stamp ASC
LIMIT 1;
HIST_PV is the column where I’m storing data. ReplayDateDiff is the tag where I’m storing my time span difference.
Now I need to do this for about ~400 tags and want to make sure that I get it right before I deploy this system to collect.
It seems like my approach is going to be tedious to configure, but I don’t know how else to do it. Do any of you have any suggestions for better ways to do this?
