I moved some tags from one folder to another in the SQLTags browser, and perhaps coincidentally, historical logging has stopped working.
I am getting the following error;I am using SQL Server Express and Version 7.0.3 (b4519) of Ignition.
I don’t understand the error, as thetable sqlth_drv does exist, so I’m not sure why Ignition is trying to create it again.
com.inductiveautomation.ignition.gateway.web.pages.config.systemconsole.LogViewer$SerializableLoggingEvent$ClonedThrowable: Error running query: CREATE TABLE sqlth_drv ("id" int IDENTITY(1,1),"name" varchar(255),PRIMARY KEY ("id"))
com.inductiveautomation.ignition.gateway.db.schema.DBTableSchema.executeCommandSet(DBTableSchema.java:96)
com.inductiveautomation.ignition.gateway.db.schema.DBTableSchema.createTable(DBTableSchema.java:67)
com.inductiveautomation.ignition.gateway.db.schema.DBTableSchema.verifyAndUpdate(DBTableSchema.java:60)
com.inductiveautomation.ignition.gateway.history.sinks.TagHistoryDatasourceSink.checkTables(TagHistoryDatasourceSink.java:482)
com.inductiveautomation.ignition.gateway.history.sinks.TagHistoryDatasourceSink.initialize(TagHistoryDatasourceSink.java:144)
com.inductiveautomation.ignition.gateway.history.sinks.AbstractSink.tryToInit(AbstractSink.java:81)
com.inductiveautomation.ignition.gateway.history.sinks.TagHistoryDatasourceSink.tryToInit(TagHistoryDatasourceSink.java:135)
com.inductiveautomation.ignition.gateway.history.sinks.AbstractSink.isAccepting(AbstractSink.java:98)
com.inductiveautomation.ignition.gateway.history.sinks.AbstractDatasourceSink.isAccepting(AbstractDatasourceSink.java:75)
com.inductiveautomation.ignition.gateway.history.sinks.TagHistoryDatasourceSink.isAccepting(TagHistoryDatasourceSink.java:175)
com.inductiveautomation.ignition.gateway.history.sinks.AggregateSink.isAccepting(AggregateSink.java:81)
com.inductiveautomation.ignition.gateway.history.ForwarderThread.run(ForwarderThread.java:74)
com.inductiveautomation.ignition.gateway.web.pages.config.systemconsole.LogViewer$SerializableLoggingEvent$ClonedThrowable: There is already an object named 'sqlth_drv' in the database.
com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:196)
com.microsoft.sqlserver.jdbc.SQLServerStatement.getNextResult(SQLServerStatement.java:1454)
com.microsoft.sqlserver.jdbc.SQLServerStatement.doExecuteStatement(SQLServerStatement.java:786)
com.microsoft.sqlserver.jdbc.SQLServerStatement$StmtExecCmd.doExecute(SQLServerStatement.java:685)
com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:4026)
com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:1416)
com.microsoft.sqlserver.jdbc.SQLServerStatement.executeCommand(SQLServerStatement.java:185)
com.microsoft.sqlserver.jdbc.SQLServerStatement.executeStatement(SQLServerStatement.java:160)
com.microsoft.sqlserver.jdbc.SQLServerStatement.executeUpdate(SQLServerStatement.java:642)
org.apache.commons.dbcp.DelegatingStatement.executeUpdate(DelegatingStatement.java:228)
com.inductiveautomation.ignition.gateway.datasource.DelegatingStatement.executeUpdate(DelegatingStatement.java:79)
com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper$SRStatement.executeUpdate(SRConnectionWrapper.java:634)
com.inductiveautomation.ignition.gateway.db.schema.DBTableSchema.executeCommandSet(DBTableSchema.java:94)
