History Splitter Feature Request
I’m not sure if this feature has already been requested, but I’d like to propose an “older-than query date” setting for the History Splitter.
The idea is to define a cutoff date that determines which historian is used for queries. Any history request that goes older than the cutoff would be served from the legacy historian (e.g., the SQL historian), while requests newer than the cutoff would be served from the new historian (e.g., Ignition Core historian).
This would make it much easier to migrate to a new historian while maintaining continuity, without needing to backfill all historical data immediately.
Example:
Query range ends before cutoff → read from legacy historian
Query range starts after cutoff → read from new historian
Query range spans the cutoff → automatically split and merge results from both historians
The current setting only sets date range size limit not a defined cut off threshold.
This is a very good idea. If you make a proper feature request on ideas.inductiveautomation.com, I'll vote for it.
(Put links here and there for reference.)
Here is the link to the feature request
