Horizontal Bar Chart - XY Chart
Is there a way to use the XY chart for a bar graph that is horizontal instead of vertical?
Sure.
XY horizontal bar chart
XY Chart JSON
    "type": "ia.chart.xy",
    "version": 0,
    "props": {
      "title": {
        "text": "props.title.text"
      "xAxes": [
a>          "name": "count",
          "label": {
            "enabled": true,
            "text": "props.xAxes.0.label.text",
            "color": ""
          "visible": true,
          "tooltip": {
            "enabled": true,
            "text": "",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "inversed": false,
>          "render": "value",
          "category": {
            "break": {
              "enabled": false,
              "startCategory": "",
              "endCategory": "",
              "size": 0.05
          "date": {
            "baseInterval": {
              "enabled": false,
              "timeUnit": "hour",
              "count": 1,
              "skipEmptyPeriods": false
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startDate": "",
              "endDate": "",
              "size": 0.05
            "inputFormat": "yyyy-MM-dd kk:mm:ss",
            "format": "HH:mm"
          "value": {
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "logarithmic": false,
            "break": {
              "enabled": false,
              "startValue": 0,
              "endValue": 100,
              "size": 0.05
            "format": "#,###.##"
          "appearance": {
            "opposite": false,
            "inside": false,
            "labels": {
              "color": "",
              "opacity": 1,
              "rotation": 0,
              "verticalCenter": "middle",
              "horizontalCenter": "middle"
            "grid": {
              "color": "",
              "opacity": 1,
              "dashArray": "",
              "minDistance": 60,
              "position": 0.5
            "font": {
              "size": "",
              "weight": 500
      "yAxes": [
b>          "name": "category",
          "label": {
            "enabled": true,
            "text": "props.yAxes.0.label.text",
            "color": ""
          "visible": true,
          "tooltip": {
            "enabled": true,
            "text": "",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "inversed": false,
>          "render": "category",
          "category": {
            "break": {
              "enabled": false,
              "endCategory": "",
              "size": 0.05
          "date": {
            "baseInterval": {
              "enabled": false,
              "timeUnit": "hour",
              "count": 1,
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startDate": "",
              "endDate": "",
              "size": 0.05
            "format": "M/d/yyyy HH:mm:ss"
          "value": {
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startValue": 0,
              "endValue": 100,
              "size": 0.05
          "appearance": {
            "opposite": false,
            "inside": false,
            "labels": {
              "color": "",
              "opacity": 1,
              "rotation": 0,
            "grid": {
              "color": "",
              "opacity": 1,
              "dashArray": "",
              "minDistance": null,
              "position": 0.5
            "font": {
              "size": "",
              "weight": 500
      "series": [
          "name": "props.series.0.name",
          "label": {
            "text": ""
          "visible": true,
          "hiddenInLegend": false,
          "defaultState": {
            "visible": true
          "data": {
c>            "source": "barData",
d>            "x": "count",
e>            "y": "cat"
a>          "xAxis": "count",
b>          "yAxis": "category",
          "zIndex": 0,
          "tooltip": {
            "enabled": true,
            "text": "{name}: [bold]{valueY}[/]",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "render": "column",
          "candlestick": {
            "open": {
              "x": "",
              "y": ""
            "high": {
              "x": "",
              "y": ""
            "low": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "",
                "opacity": 1
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "stacked": false,
              "deriveFieldsFromData": {
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "column": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "",
                "opacity": 1
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "stacked": false,
              "width": null,
              "height": null,
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "line": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": false,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
          "stepLine": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": true,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
      "dataSources": {
c>        "barData": [
d>            "cat": "guitars",
e>            "count": 27
            "cat": "trumpets",
            "count": 16
            "cat": "percusion",
            "count": 21
    "meta": {
      "name": "XYChart"
    "position": {
      "basis": "318px"
    "custom": {}
I've marked the important bits in the JSON with '>'. The ones preceded by a letter, such as 'a>', etc. need to match.
You'll need to remove these helpers to get the JSON to work.
Got it. Thank you.
