Below are the log messages that are generated every couple seconds. Any ideas? Gateway is acting normal despite the logs. v7.9.12
Config
20Jan2020 22:06:24
Error storing tag values.
simpleorm.utils.SException$Error: Transaction already committed, need begin.
at simpleorm.sessionjdbc.SSessionJdbc.checkBegunThread(SSessionJdbc.java:353)
at simpleorm.sessionjdbc.SSessionJdbc.rollback(SSessionJdbc.java:408)
at com.inductiveautomation.ignition.gateway.localdb.PersistenceInterfaceImpl.getSession(PersistenceInterfaceImpl.java:57)
at com.inductiveautomation.ignition.gateway.localdb.PersistenceInterfaceImpl.getSession(PersistenceInterfaceImpl.java:44)
at com.inductiveautomation.ignition.gateway.sqltags.tagproviders.internal.InternalTagStore.openIfNot(InternalTagStore.java:1303)
at com.inductiveautomation.ignition.gateway.sqltags.tagproviders.internal.InternalTagStore.internalStoreTagValues(InternalTagStore.java:1341)
at com.inductiveautomation.ignition.gateway.sqltags.tagproviders.internal.InternalTagStore.storeTagValues(InternalTagStore.java:1250)
at com.inductiveautomation.ignition.gateway.sqltags.providers.AbstractStoreBasedTagProvider.tagValuesChanged(AbstractStoreBasedTagProvider.java:2432)
at com.inductiveautomation.ignition.gateway.sqltags.scanclasses.SimpleExecutableScanClass$ScanClassTagEvaluationContext.processAndReset(SimpleExecutableScanClass.java:1141)
at com.inductiveautomation.ignition.gateway.sqltags.scanclasses.SimpleExecutableScanClass.run(SimpleExecutableScanClass.java:901)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$SelfSchedulingRunner.run(BasicExecutionEngine.java:483)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:565)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
20Jan2020 22:06:24
Attempting to open new session, but session already open for this thread.
java.lang.Exception: null
at com.inductiveautomation.ignition.gateway.localdb.PersistenceInterfaceImpl.getSession(PersistenceInterfaceImpl.java:56)
