Hourly Chart with Single Tag
I need some support with this. I have a hourly chart I would like scripted. I want so that it has live data within its time frames but once that time frame is done it remains in the last value of that time frame. I have a single tag that will be the one giving the values(the highlighted tag). any advice would help!
I recommend that you record the count every hour and save it in a database.
You asked for a "chart", but I think you mean a "table" and the table component with a database binding would be very simple and tidy.
Another option for this would be to create a Dataset tag with each of the time frames that you want to store, and then on the hour trigger record the tag value into that. Then a simple tag binding to a table, or some other form of mapping can be used to display the data.
This will work so long as you don't care to abandon the data after 24 hours.
thats actually what I have right now, but I wanted it show it incrementing live while its on each time frame
Hi, I thought of this but I didn't go with this solution because like I mentioned I want the live data when it is going thru the current time frame. Unless I am wrong and what you said is capable of doing that
Query tag polling
You would create a named query - usually with some search criteria parameters - and then use that in a Query Binding.
I think you're using Vision (add the tag from the dropdown below your question title) and I do little work in that so it may be different to how this would be done in Perspective.
