How can i access MYSQL through web
is there any way to access mysql through web?? what is the steps for that?? as i am out side the office and need to make edit to my database
i tried to use this link " jdbc:mysql://localhost:3306/test"
host: IP address of the database server.
thanks
Tamer
To remotely edit a MySQL database, you will have to set up port forwarding from your office router to your MySQL server. If your office public IP address was 1.2.3.4, you could set up port 4000 (for example) on your router to forward to your MySQL server port 3306 (the standard MySQL port).
You would then access MySQL remotely using something like MySQL Workbench pointing at 1.2.3.4:4000.
Unfortunately unless you have already set up port forwarding you won’t be able to do anything from outside your network.
Thanks a a lot AlThePa for your assist. i will try and send you the result .Thanks a gain.
Tamer
