How can I fill the area under the curve in Perspective Time Series chart?
Hello,
how can I fill digital chart (Attached photo) instead of line. we can select digital area in report for that reason but, I couldn’t find a way to do the same in perspective view to see it live.
What is “digital chart” and “digital area”? There are no components with these names.
I want to see filled area instead of line. if you see attached photo you can see the line green line as show 1. i want to see filled area between 0-1 all green. we can do it in report if we select “digital area” instead of “line”
Report.
Perspective components are different from Vision components which are different from Report components. Features vary. Sometimes there are work-arounds.
Which Perspective chart type is that? XY Chart?
If it is an XY Chart then set
props.series.0.line.appearance.fill.opacity: 0.5
it is TimeSeriesChart
That’s what I was asking when I queried your term “digital chart”.
Time Series Area type
You need to select Time Series Chart | Area instead of Line.
Thank you very much. I got it. I was looking for complicated way, but this one was really easy.
