v8.1.0
I can’t seem to set the default alarm status table column widths. In Designer in run mode, I set the widths, then save and go back into designer mode and the columns reset… The datetime field is as long as the display path field
v8.1.0
props -> columns -> your column -> width (without px) and strictWidth is true
