How can I tell Ignition if my tag's value is over a certain number, then have it light up my multi-state indicator?
I have these tags:
I'm using getBit to grab the bits from my integer tag.
My question is, for my last tag, how do I make a tag that will identify if the value is over 16384?
Granted, I am new to Ignition, but this was one I should've caught.
I did not realize I could use if (TagWithIntValue > 16384, 1, 0). I was under the impression I needed to use bits and realize now I can just base my expression tag off the integer value tag that this expression tags is looking at.
Glad you worked it out, but the if statement there is redundant. You can just use {tag} > 16384 which evaluates to true or false. You only need to use if if you're returning values other than true/false
Oh cool! I'll keep that in mind. Thanks for the tip.
