Is ther a way to valide that a view exist?
Actually I use a script with hardcoded path, but I search a way to do that more efficially with binding path.
My script;
path = “C:/Program Files/Inductive Automation/Ignition/data/projects/AMT/com.inductiveautomation.perspective/views/1-UDTS\AS0153_TRIM_PRESS/SETUP/Elems”
value = system.file.fileExists(path + “/Extras/ejector_closed_position”)
return value
I have a button that I want to root to a specific view if the view exit.
Anyone have better solution for me?
You should be putting all of your code within preformatted text characters ``
This = some_code
If you_add:
Tabs = 'they remain intact'
I don’t understand your explanation. How can I validate if a view exist in a specific folder of my project?
He’s saying you should post your code by putting it between
my code here
so that it gets formatted and we can read it better
From your post its hard to tell exactly what your script is, how it’s being called, if its inside a function, etc. However, I think it sounds like you just want a function that checks if a file exists? system.file.fileExists already does that. But if you ar einclined to make your own function, you can do
def fileExists(filePath):
Checks if a file exists.
Args:
filePath: str, file path to check
Returns:
boolean, true if file exists, false otherwise
import system.file
return system.file.fileExists(filePath)
I know that and I want to build my own function, but I don’t want to have to specified the local path of my perspective project manually. I search a way to be able to get the direct path to my perspective project folder.
self.view.custom_view_path = C:/Program Files/Inductive Automation/Ignition/data/projects/AMT/com.inductiveautomation.perspective/views/
I search a way to get that path withaout having to declared it manually. How to get perspective view path of my project?
viewPath = "1-UDTS/AS0153_TRIM_PRESS/SETUP/Elems/Extras/"
fullPath = self.view.custom.views_path + viewPath
tags = system.tag.browseTags(parentPath=value["items_path"])
tags_dict = {}
for tag in tags:
if value["mode_text"]=="install":
if self.parent.custom.when==self.parent.custom.constants_setup_item_when.always or self.parent.custom.when==self.parent.custom.constants_setup_item_when.install_only:
add_need=True
else:
add_need=self.view.custom.show_all
elif value["mode_text"]=="uninstall":
if self.parent.custom.when==self.parent.custom.constants_setup_item_when.always or self.parent.custom.when==self.parent.custom.constants_setup_item_when.uninstall_only:
add_need=True
else:
else:
if add_need:
tags_dict[tag.fullPath] = system.tag.read(tag.fullPath + "/preset/sort_order").value
tags_sorted = sorted(tags_dict.items(), key=lambda x: x[1])
instances = []
for k, v in list(tags_sorted):
my_dict={}
my_dict["instanceStyle"]={}
my_dict["instanceStyle"]["classes"]=""
my_dict["instancePosition"]={}
my_dict["title"] = "tp_setup_" + k.rsplit("/",1)[1] + "_title"
my_dict["description"] = "tp_setup_" + k.rsplit("/",1)[1] + "_" + value["mode_text"]
my_dict["item_path"] = k
my_dict["popUp"]=self.view.custom.popUp
my_dict["show_all"]=self.view.custom.show_all
my_dict["clic_enabled"]=self.view.custom.clic_enabled
my_dict["path"]=self.view.params.path
my_dict["access_role"]=self.view.params.access_role
my_dict["needs_type"]=value["needs_type"]
my_dict["mode_text"]=value["mode_text"]
if system.file.fileExists(fullPath + k.rsplit("/",1)[1] + "_" + value["mode_text"]):
my_dict["custom_view_exist"] = True
my_dict["custom_view_name"] = viewPath + k.rsplit("/",1)[1] + "_" + value["mode_text"]
else:
my_dict["custom_view_exist"] = False
my_dict["custom_view_name"] = None
instances.append(my_dict)
return instances
