I am working with Time Series Chart And I want to customize the X and Y Axis text.
Currently I have some default values on Axis that comes with the sample data. Also can we add a Name for each bar in Time Series Chart?
For Y-Axis I need to show: The Values of a column that is not present in the series data.
For X-Axis I need to show: "Brass Tags"
And for each Bar I need to show: BT1, BT2 ...
I don't think the Time Series chart has any notion of categories on the X-axis. You should probably be using the XY Chart.
can we do customize axis in xy chart?
Can you show us a mockup of what you want. A photo of a pencil sketch would probably do as long as it's clear to us what the x-axis categories are and whether they're all the same size and / or time-related.
Currently for the Y axis I have the Numbers.
Using an XY Chart, start with,
xAxes.0.render : category
