I also tried named query using the same way to set a variable but it failed too.
I know there are other ways that allow me to add index to the display table, but for me , to add it in the query is the most ideal method and I really wanna make it work.
You’re running 2 queries in a single call. You can’t do that with system.db.runQuery()
Query 1
SET @i := 0;
Query 2
SELECT ......
Not sure if you can just call the runQuery twice, one for each statement, or if you need to begin a transaction for the session variable to work.
EDIT
Okay, so I got curious and tested it out.
This is possible to do in a single statement.
SELECT
(@i:=@i+1) as 'index',
t.time as 'time',
t.v as 'v'
FROM send_h t, (SELECT @i:=0) itterator
WHERE t.time BETWEEN '2021-04-02 12:00:00' AND '2021-04-03- 12:00:00'
