How center text in an embedded SVG?
(This is for a perspective in 8.1.15)
So I am experimenting with with custom SVGs. I created a simple button face plate that looks like this:
Screen Shot 2022-03-23 at 3.19.11 PM
Each line of text is a separate text element.
The contents of the SVG are:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<!DOCTYPE svg PUBLIC "-//W3C//DTD SVG 1.1//EN" "http://www.w3.org/Graphics/SVG/1.1/DTD/svg11.dtd">
<svg width="100%" height="100%" viewBox="0 0 284 511" version="1.1" xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink" xml:space="preserve" xmlns:serif="http://www.serif.com/" style="fill-rule:evenodd;clip-rule:evenodd;stroke-linejoin:round;stroke-miterlimit:2;">
    <g id="BasePlate">
        <circle id="Circle" cx="141.732" cy="368.504" r="141.732" />
        <rect id="Outline" x="0" y="-0" width="283.465" height="368.504" />
        <rect id="Inset" x="14.173" y="14.173" width="255.118" height="192.756" style="fill:#fff;" />
    </g>
    <g id="Text">
        <text id="Text1" x="17.523px" y="51.69px" style="font-family:'ArialMT', 'Arial', sans-serif;font-size:36px;">Loren Ipsum xx</text>
        <text id="Text2" x="17.523px" y="85.29px" style="font-family:'ArialMT', 'Arial', sans-serif;font-size:36px;">Loren Ipsum xx</text>
        <text id="Text3" x="17.523px" y="119.13px" style="font-family:'ArialMT', 'Arial', sans-serif;font-size:36px;">Loren Ipsum xx</text>
        <text id="Text4" x="17.523px" y="152.73px" style="font-family:'ArialMT', 'Arial', sans-serif;font-size:36px;">Loren Ipsum xx</text>
        <text id="Text5" x="17.523px" y="186.33px" style="font-family:'ArialMT', 'Arial', sans-serif;font-size:36px;">Loren Ipsum xx</text>
    </g>
</svg>
I dragged this image into a perspective view and successfully linked parameters to the text elements.
But within Ignition I wanted to format the text as centered. So I drilled down to the contents of the SVG and applied a center format like so:
Screen Shot 2022-03-23 at 3.12.39 PM
But the text remains left justified:
Screen Shot 2022-03-23 at 3.15.27 PM
Is it possible to do what I want, and justify the text from within Ignition, or can I only do this by applying some sort of justification directly in the SVG (and if so, how)?
Hey @peter,
Maybe this is what you’re looking for? Let me know if this works or not: text-anchor - SVG: Scalable Vector Graphics | MDN
I can see how that works by changing where the X/Y coords are with respect to the text. I’m guessing that is probably the best I can do within the SVG itself.
I just found find this: How to place and center text in an SVG rectangle and that starts to get way too complicated for me!
Of course I just discovered that my SVG editor of choice (Affinity Designer) doesn’t support “text-anchor” … :face_with_symbols_over_mouth:. So every time I want to edit my master SVG project I’ll have to manually manipulate the text-anchor of the exported SVG (and yes I know about Inkscape)
Hi @ayu I’m taking back my solution check. It looks like Perspective doesn’t respect the “text-anchor”.
Here is a subset of my new SVG file
<text id="Text1" x="141.732px" y="51.69px" text-anchor="middle" style="font-family:'ArialMT', 'Arial', sans-serif;font-size:36px;">Loren</text>
The x coordinate is set to be the middle of the image.
And here is what the file looks like dragged into a Perspective view:
Screen Shot 2022-03-23 at 4.40.14 PM
So you can see the text has been located to the middle of the image, but it is still left aligned.
But if I open the image directly in my browser I see this:
Screen Shot 2022-03-23 at 4.42.29 PM
Hey @peter,
Yea that look’s odd. Looks like this may be a potential bug in Perspective. Would you mind posting your test SVG so I can take a look at how the attributes are being applied?
Here is the latest image.
    <g id="BasePlate">
    </g>
    <g id="Text">
        <text id="Text2" x="141.732px" y="85.29px" text-anchor="middle" style="font-family:'ArialMT', 'Arial', sans-serif;font-size:36px;">Loren</text>
        <text id="Text3" x="141.732px" y="119.13px" text-anchor="middle" style="font-family:'ArialMT', 'Arial', sans-serif;font-size:36px;">Loren Ipsum</text>
        <text id="Text4" x="141.732px" y="152.73px" text-anchor="middle" style="font-family:'ArialMT', 'Arial', sans-serif;font-size:36px;">Loren Ipsum</text>
        <text id="Text5" x="141.732px" y="186.33px" text-anchor="middle" style="font-family:'ArialMT', 'Arial', sans-serif;font-size:36px;">Loren Ipsum</text>
    </g>
</svg>
As you can see the x coord of the text is same as the cx coord of the circle.
Given that my editor of choice doesn’t support creating the text-anchor, I may take the less painful path and just slap the text into the view from within Perspective.
Hey @peter,
It looks like the text-anchor attribute doesn’t get applied during import or when adding the property value manually. I will file a ticket for this bug. This is a bit tedious but as a workaround you can add the attribute textAnchor: middle to the style object of the text element like so:
Thanks for that! And I’ll add another notch to my bug count!
We should get a badge to track our bug count.
Well text-anchor is a style but is not inside the style string.
i think if you move it in there than the designer will recognize it.
My understanding is that text-anchor is an attribute, but that text-align is a style.
And in hindsight I may actually be wanting to use text-align. I’ll have to test that today.
Ah hm, yes they are both an svg attribute and style, seems igntion only will recognize it as a style.(probably)
And im guessing most svg editors will put it as an attribute :frowning:
text-align wont work in svg
you already tested that yesterday xp
I’m glad to find this workaround to center text, but is there a bug fix in the works to apply the textAnchor attribute in an embedded SVG? I am using 8.1.18 and still have this issue.
Has that issue been properly solved ?
I am currently using 8.1.35 and both the style textAnchor and the SVG attribute text-anchor are honored in the way that I would expect.
Bit old, but I second this; I've raised 265 or so bug reports :grinning_face_with_smiling_eyes: albeirt most of those were for 8.0.x
+212 feature requests, while we're here, excluding individual feature requests for the Power Chart... counting those it'd be like 2012 :grimacing:
Also, I've found (v8.1.47) that when embedding text (from Plan SVGs exported from Inkscape), that text is included into an element "text" group which contains "t-span" sub-elements. I can't get text to be positioned correctly unless I delete the whole sub-elements folder that includes the t-span(s), and then add a "text" prop to the parent and set the text. Then the text appears in the same location as saved in the Inkscape :confused:
Seems like a bug in the embed SVG logic
