Hello
I need some help on how to change the default font size of markdown component in perspective. The inline style doesn’t work and I’m scared to use html for the security reason so I wonder is there any trick so I can change the font size and family?
I believe this was introduced recently in the 8.0.13 builds as a part of the large theming CSS refactor. What version of Ignition are you using?
Hi Ray
Yes you are correct I’m not using 8.0.13.
Thanks it is solved.
