How display the last 10 entries of a table?
Good day, I am using this expression to filter a table. I want to only display the last 10 entries. How do i filter that out?
SELECT
“HS10_End_Time”
,“HS10_Start_Time”
,FORMAT((“HS10_End_Time” - “HS10_Start_Time”), ‘HH:mm:ss’) as Duration
FROM
Misc_Rail_LGV_Call_Time
WHERE
“HS10_End_Time” IS NOT NULL
Thank you
In MS SQL it would be select top 10…
In MySQL/maria it’s Select… Limit 10
Use Order by asc/desc to get the right order
I got ya. This works, THANKS!
SELECT TOP 10
“HS10_End_Time”
,“HS10_Start_Time”
FROM
WHERE
ORDER BY
“misc_rail_lgv_call_time_ndx” DESC
