I have enabled auditing and have created and associated an Audit Profile. How can I display the contents of the logs in a project window. Thanks
Do the following:
- Drag a table component into a window from the tables tab of the component palette
- Bind the data property of the table to a function binding.
- Select the audit log function from the dropdown list
- Setup your params and try it out.
Travis,
The steps that you provided were exactly what I needed. Thank you for your assistance.
Shelly
