How do I ask SQL timestamp conditions?
where t_stamp between x and y
how do I properly ask SQL date questions related to t_stamp?
Like if I wanted the count during the last 5 minutes
or if I wanted the count during the month of october
You didn't mention what flavour of SQL, so speaking pseudo;
datepart(now, -5, minutes)
DATEPART(mm, t_stamp) = 10
or your first line is perfectly valid, just longer;
where t_stamp between '2021-10-01' and 2021-10-31'
w3 schools etc is pretty good for this
Thanks, I am on the w3 page for date
however, I don’t see where it says like now
so I copied your example, switched the October to November, got an error of out of range
so how do you handle a now() scenario? Can you use now(30000)?
really odd, with 2021-11-31 I get an error
with 2021-12-01 I don’t get an error
edit: oh no
oops
well all dates are going to be 1st to 1st now lol
MS SQL Server?
MySql/Maria?
PostGres?
etc?
I think it is just regular sql, I am using sql bridge
Try this and if it works it’s MS SQL
WHERE tstamp > DATEADD(minute, -5,  GETUTCDATE())
(t_stamp between '2021-10-01' and '2021-11-01' or t_stamp > DATEADD(minute, -500,  GETUTCDATE()));
both work, thanks very much
how often does the query get called if I bind it to a label on a perspective page though?
can I have it update every 30 seconds?
If you are using a query binding there is a polling option that you could set to 30 seconds.
If you are running the query from a script, then maybe you could create a custom property on your label, put the query binding on the custom property, then access the data from the custom property in your script.
I will look for the setting in the binding I am using
